I install ubuntu-mate-desktop alongside kubuntu…and everything is working well. The only issue I have found is I don’t have tap to click working. I went to control panel and the mouse menu. Unfortunately the tab for touchpad is missing. Any idea what would cause this? Thanks for any help.
Hi @pc17,
have you done a full system update and have you tried running any fixes using Welcome?:
Thanks for the reply and the guide. That’s really handy. It did not occur to me to try Welcome unfortunately. I ended up installing Solus Mate to give that a try…and I have the same issue. No touchpad menu in the Mouse section of the control panel.
Hi @pc17,
sorry but I don’t know anything about SolusOS!.
I thought it odd that I had the same issue in Ubuntu Mate and Solus Mate but I found a fix for it in this thread
