Hello,
I want to mount a NAS share at startup on my Raspberry Pi 2 with Ubuntu Mate 15.10.1
I have added a line to /etc/fstab and when I type :
mount -a
the directory is mounted properly
But I don’t know how to mount it automatically at startup.
Thank you for your help
Have a look in the detailled steps described with the article “Sticky Mounting NAS Drives” article using the utility Gigolo.
I have looked at Gigolo and it works : I can mount NAS share at startup
On my desktop, there is an icon “multimedia on nas”
I would like to know the path to the “multimedia on nas” folder so I can enter it in Madsonic
I have tried : smb://nas/multimedia but it does not work
I had to add this command
“sleep 5”
before the “mount -a” command
so the raspberry waits for the network to be up
thanks anyway
Understand that you have to add a “sleep” statement before mounting. So does this resolve your issue you’re facing and can properly mount NAS drives upon reboot?
Yes it resolve the issue
I can properly mount NAS drive upon reboot
OK & great. Then please mark your post as resolved so that others know about the solution
