Hi all,
I just picked up a netbook with 64 gigs EMMC and installed Mate 18.04. I decided to see how Dolphin would work, and put some games on my micro sd card. For whatever reason, Dolphin can't access that mount point. Is there some way to change it? Google let me down on this one.
Thanks!
Edit:
Nevermind, I wend to uninstall it, and I found out that in the store there is a permissions manager with this option.
I got it working.
