BAW
14 December 2018 20:04
1
Hello,
I had unbuntu mate running on my raspbery pi 3. I ran into an issue with trying to get it to auto login. As a result I can’t log in anymore.
I created a new SDK card that is running. I would like to get a file off of the old SD card running the ubuntu mate I can no longer log into.
I got a SD card read and connected it to my raspberry pi via USB. I want to mount it and get my file off.
I have run fdisk -l
I do not see it in the results.
Any ideas as to what I might try?
Thanks
Mickey
14 December 2018 20:37
2
I am running UM on a Raspberry Pi 3, too. After connecting a SD Card Reader (same dimensions as the raspberry pi) via USB there are no problems. If you run lsblk
is the SD Card named there?
Mickey
Mickey
14 December 2018 20:41
3
According to your problems with autologin:
You have to create a new file called 12-autologin.conf
in the directory
/etc/lightdm/lightdm.conf.d/
adding this lines:
[SeatDefaults]
autologin-user=username
Mickey
