Hello,
I’m upgrading a Gnome 14.04 LTS system to Mate 16.04 LTS via a virgin install. I have a western Digital MyBookWorld NAS that I keep all my critical files on. With 14.04, the following line in /etc/fstab mounts the NAS.
10.1.0.3:/nfs/Public /media/public nfs nolock,rw,hard,intr 0 0
On Mate,
`$> sudo mount -v /media/public’
fails with the following
root@John-laptop:/etc# mount -v /media/public mount.nfs: timeout set for Sun Nov 13 18:39:53 2016 mount.nfs: trying text-based options 'nolock,hard,intr,vers=4,addr=10.1.0.23,clientaddr=10.1.0.23' mount.nfs: mount(2): Permission denied mount.nfs: access denied by server while mounting 10.1.0.23:/nfs/Public root@John-laptop:/etc#
I can mount the share using the command line
$> sudo mount -v 10.1.0.23:/nfs/Public /media/public
It produces this output
root@John-laptop:/etc# mount -v 10.1.0.3:/nfs/Public /media/public mount.nfs: timeout set for Sun Nov 13 17:25:14 2016 mount.nfs: trying text-based options 'vers=4,addr=10.1.0.3,clientaddr=10.1.0.23' mount.nfs: mount(2): Protocol not supported mount.nfs: trying text-based options 'addr=10.1.0.3' mount.nfs: prog 100003, trying vers=3, prot=6 mount.nfs: trying 10.1.0.3 prog 100003 vers 3 prot TCP port 2049 mount.nfs: prog 100005, trying vers=3, prot=17 mount.nfs: trying 10.1.0.3 prog 100005 vers 3 prot UDP port 773 root@John-laptop:/etc#
In other words it worked after using version 3 protocol and UDP transport on port 773
So my question is, what do I need to do to make mount using /etc/fstab work? I’ve been working on this a couple of days now and have tries every combo of proto and nfsproto that the man pages list.
Also what are the "prog"s the debug output references and can a particular one be invoked.
John
Please be gentle. This is my first post here.
