OK, cool, that’s what I, precisely, wished to know @lah7 - for all of us who can utilize this workaround .
Will you keep up with this issue, a little bit - to let us know when we can safely update? Or are there too many variables to bank on whether a future update/bug-fix would be comprehensively relevant.
I'm afraid I wouldn't know when it's safe to update, since it hasn't affected my desktop (NVIDIA, Compiz) or my netbook (Intel, can't test, it can only run Marco). As the report suggests, this fix was for Unity, but it seems it's broken MATE in some way.
You should file a bug report when running the new, affected version and note this is a regression for the MATE desktop on some hardware.
You could use apport, which will gather system information and report compiz based on the version you're running: (unlock and upgrade to make this report accurate)
apport-bug compiz
Be sure to also add Affects package/distro: ubuntu-mate to the report and link it here so others can confirm it happens to them too.
The other way is to file a bug report in the Issue Tracker with as much detail as possible, so @wimpy and other bug monitors can confirm and provide feedback on the matter. The maintainer may be able to hold back the package for now.
Login as guest user or newly created user isn’t effected with this BIG X cursor bug. what will be the reason for it. so if that’s the case i can move in to new user name rather than reinstalling OS.
We still have at least one computer, over here, with the bug still active (upgraded), so the apport-bug compizwill get in the mix. I will also file a bug report in the Issue Tracker, with details; so @wimpy and other bug monitors may confirm and provide feedback on this issue.
It, indeed, would be cool if the maintainer would be able to hold back the package for now - and keep it from doing this again - even with an upgrade!
Hmm, in that case @Buddhika_Jayasingha, there could be something wrong with the existing configuration or some customizations. @mated, can you confirm if a guest session / new user “fixes” the problem? Saying that, I think it uses Marco by default, which isn’t affected.
By the way @mated, it sounded like you plan to create two reports (one with apport, the other manually)… that’s wouldn’t be helpful for developers/maintainers, instead, for the first report you’ll see a “This affects distro/package…” button, in which you can add ubuntu-mate.
I might take a peak at the code changes later, to see how this one change in this update has caused this unusual regression… I don’t understand why I (and other users?) haven’t been affected.
I was successful in talking the good wife, who still happens to be using 15.10 - with the active bug, into taking this on. The bug report part is done.
Thanks, again @lah7; for fostering this one a bit; there will be more who will also be grateful !
Okay, got it, on the report part, @lah7. As far as the guest user deal goes, I have not yet had the wife log in as a different user, to see; but I am guessing it would fix it. However, this, as you point out, would only be because Marco (if it is setup that way) would be in charge at that time. There are no issues with Marco, over here; but @Buddhika_Jayasingha could easily see, by switching to Marco -in MATE Tweaks - logged in as normal (no guest user, etc.).
I will have her check that out as a guest user, though, and report back.
Thanks for reporting that. Anyone who has the same exact same problem is encouraged to click on "This bug affects x person, Does this bug affect you?"(when logged in) to raise the heat of the bug.
The link "Also affects project" is how it gets linked to ubuntu-mate, so now it appears in the Ubuntu MATE Issue Tracker too. I already did this, so it's okay. I shortened the title to a more summary of what's happening - invisible or black X cursor.
I haven't found the code changes (Launchpad confuses me...) So why this is happening, remains to be seen. For now, there's the locking version workaround or to switch to Marco for the time being.
Will it end up getting the bug fixed any time soon, or will I have to go back to Mint Mate? In all due respect, I do not really have the time for this in my mix.
Does Ubuntu Mate have any know issues with Dells? I have been recommending Ubuntu Mate to everybody but this will look real amateurish to anyone who has downloaded it (and a lot of us have Dells like me).
Like any bug, it depends on how complex this problem introduced and if the developers who understand this stuff have time to fix it, plus any delay when Ubuntu devs review and release a new update. Switching distros doesn't really make sense since Ubuntu MATE hasn't suddenly become unusable -- Marco isn't affected and the previous versions of compiz packages can be locked.
Since this update fixed a bug in Unity (which uses Compiz), it could be possible some other Compiz-powered desktops have been affected by this change, including Mint MATE if it uses Compiz.
Keep this thread/bug report bookmarked for updates.
Any Linux distro I tried worked well on my Dell Inspiron Duo, it also had no issues on an old Dell Pentium 4 PC, so results may vary on the age of the PC. -- Please create a new thread to discuss this as this thread will get derailed.
I want compix - not marco. I tried to rollback; but it will remove things that it can’t figure out how to put back. That is what I meant by " I do not really have the time for this in my mix" I am assuming that new releases (and before that point upgrades) will at least have the old compiz (good) package preinstalled w/ a lock to prevent this again?
When do we get the bug fix? I gotta have Compiz for my mini window previews, I can’t do with Marco because I got used to years of window previews with Windows 7. I will just have to put up with the invisible mouse arrow/ big X until you fix it, because I can’t do all that IT stuff. The IT guy at work said that the upgrade is prob not compatible with my stock Dell hardware (or something like that).
We started using Ubuntu Mate at my job, and when MS hijacked my system and put Windows 10 on it, I just switched to Umate. This such a great operating system (even with the stupid mouse - thank you!
I, too, have a Dell; and by the looks of these threads, so far, I only see Dell mentioned. As a matter of fact, all of the PC’s affected by this bug - over where I am at - are, indeed Dells. @lah7 has stated that he has plenty of Dells, I wonder if he has done this Compiz update with any of them - in order to, maybe, pinpoint the potential Dell- centric hardware involved.
@Buddhika_Jayasingha, thanks for adding your name to the bug report; that is terrific community involvement/support - especially, since you have switched off of Compiz, and seem to be okay with Marco ! Are you, by chance, experiencing this issue on a Dell?
