I want to make mpv the global default for Video Player.
I know I can change Caja settings for each file type but there are a lot of video file types.
In the Preferred Applications dialog, the only options are Celluloid and RhythmBox.
Try going to system>preferences>personal>preferred applications>multimedia. It should be under the drop down list there.
