Hi!
I need multiple tabs in Mate-Terminal.
Is it possible to open Mate-Terminal with multiple tabs?
It's not fun to do that manually
When yes, how?
I cannot find something about tabs-settings in "Edit/Profile Preferences".
Hi!
When yes, how?
mate-terminal --window --tab --tab
(this will pop a new window with 2 add'l tabs)
Or maybe change for another terminal app. Like Tilix.
If I remember well, you can press CTRL+SHIFT+T to open a new tab.
If you click on file, you should see new tab with the shortcut on the same line.
I don't use MATE terminal anymore! Hope it helps!
You can set up a full configuration to automatically open with terminator;
You can add child window splits to the default profile :
The only thing its that its not inside mate terminal but as described, inside terminator
Thanks all, but that is what I need ![]()
mate-terminal --window --tab --tab --tab (3 tabs)
Why not try using screen or byobu. Personally been using screen for decades.
Is there a way to also open the Mate terminal via "Open in Terminal" with for example 3 tabs in Caja?
I cannot set the Caja extension "Open in Terminal". No config is there.
Is there a hack? Maybe via DCONF Editor?
In DCONF: /org/mate/caja-open-terminal
is only the entry: desktop-opens-home-dir
Caja looks using your preferred app you have set up in Preferred Applications.
running x-terminal-emulator should run your default terminal emulator app
I would give a try to edit the exec-arg value in dconf adding --tab --tab
ββ[olek@apbook04u]β[~]
ββββΌ $x-terminal-emulator -v
terminator 1.91
Just found that :
Usage:
mate-terminal [OPTIONβ¦]
Help Options:
-h, --help Show help options
--help-all Show all help options
--help-terminal Show terminal options
--help-window-options Show per-window options
--help-terminal-options Show per-terminal options
--help-gtk Show GTK+ Options
--help-sm-client Show session management options
Application Options:
--disable-factory Do not register with the activation nameserver, do not re-use an active terminal
--load-config=FILE Load a terminal configuration file
--save-config=FILE Save the terminal configuration to a file
--display=DISPLAY X display to use
MATE Terminal Emulator
mate-terminal --save-config=/tmp/test
I saved config with 3 tabs in a file that i was able to load again with :
mate-terminal --load-config=/tmp/test
So now in mate config create a new profile with custom command :
I got to setup the 'test' profile as 'profile used when starting'
Its opening 3 tabs as saved in the config file with caja and when clicking on the terminal app.
Hope it helps,
Many thanks, great
