Have you downloaded some time ago ubuntu-16.04-desktop-amd64.iso
with default Unity desktop?
Yes, ubuntu-16.04-desktop-amd64.iso
Then you upgraded it to 18.04 LTS, right? But Unity was missed, is not it?
Yes, then I upgraded to 18.04 LTS, which doesn't have Unity. I actually installed Unity but it was too buggy so I installed MATE (using apt install ubuntu-mate-core ubuntu-mate-desktop
as suggested in wiki.mate-desktop.org/download#ubuntu) and uninstalled Unity (apt remove
, I believe).
Output of dpkg -l | grep unity
is:
ii dbeaver-ce 6.1.2 amd64 DBeaver Community
ii gir1.2-unity-5.0:amd64 7.1.4+18.04.20180209.1-0ubuntu2 amd64 GObject introspection data for the Unity library
ii libunity-action-qt1:amd64 1.1.0+17.04.20170405-0ubuntu1 amd64 Unity Action Qt API
ii libunity-control-center1 15.04.0+18.04.20180216-0ubuntu1 amd64 utilities to configure the GNOME desktop
ii libunity-core-6.0-9:amd64 7.5.0+18.04.20190304-0ubuntu1 amd64 core library for the Unity interface
ii libunity-gtk2-parser0:amd64 0.0.0+18.04.20171202-0ubuntu1 amd64 GtkMenuShell to GMenuModel parser
ii libunity-gtk3-parser0:amd64 0.0.0+18.04.20171202-0ubuntu1 amd64 GtkMenuShell to GMenuModel parser
ii libunity-misc4 4.0.5+14.04.20140115-0ubuntu1 amd64 Miscellaneous functions for Unity - shared library
ii libunity-protocol-private0:amd64 7.1.4+18.04.20180209.1-0ubuntu2 amd64 binding to get places into the launcher - private library
ii libunity-scopes-json-def-desktop 7.1.4+18.04.20180209.1-0ubuntu2 all binding to get places into the launcher - desktop def file
ii libunity-settings-daemon1:amd64 15.04.1+18.04.20180413-0ubuntu1.2 amd64 Helper library for accessing settings
ii libunity9:amd64 7.1.4+18.04.20180209.1-0ubuntu2 amd64 binding to get places into the launcher - shared library
rc mysql-workbench-community 6.3.10-1ubuntu16.04 amd64 MySQL Workbench
rc unity 7.5.0+18.04.20190304-0ubuntu1 amd64 Interface designed for efficiency of space and interaction.
ii unity-accessibility-profiles 0.1.11-0ubuntu4 all Accessibility Profile Manager - Unity profile data
rc unity-asset-pool 0.8.24+17.10.20170507-0ubuntu1 all Unity Assets Pool
ii unity-control-center 15.04.0+18.04.20180216-0ubuntu1 amd64 utilities to configure the GNOME desktop
ii unity-greeter 18.04.0+18.04.20180314.1-0ubuntu2 amd64 Unity Greeter
ii unity-gtk-module-common 0.0.0+18.04.20171202-0ubuntu1 all Common files for GtkMenuShell D-Bus exporter
ii unity-lens-applications 7.1.0+16.10.20160927-0ubuntu3 amd64 Application lens for unity
ii unity-lens-files 7.1.0+17.10.20170605-0ubuntu2 amd64 File lens for unity
ii unity-lens-music 6.9.1+16.04-0ubuntu3 amd64 Music lens for unity
ii unity-lens-photos 1.0+17.10.20170605-0ubuntu3 all Photos lens for Unity
ii unity-lens-video 0.3.15+16.04.20160212.1-0ubuntu3 amd64 Unity Video lens
ii unity-schemas 7.5.0+18.04.20190304-0ubuntu1 all Interface designed for efficiency of space and interaction.
ii unity-scope-calculator 0.1+14.04.20140328-0ubuntu3 all Calculator scope for Unity
ii unity-scope-chromiumbookmarks 0.1+13.10.20130723-0ubuntu1 all Chromium bookmarks scope for Unity
ii unity-scope-colourlovers 0.1+13.10.20130723-0ubuntu1 all COLOURlovers scope for Unity
ii unity-scope-devhelp 0.1+14.04.20140328-0ubuntu3 all devhelp scope for Unity
ii unity-scope-firefoxbookmarks 0.1+13.10.20130809.1-0ubuntu1 all Firefox bookmarks scope for Unity
ii unity-scope-home 6.8.2+16.04.20160212.1-0ubuntu3 amd64 Home scope that aggregates results from multiple scopes
ii unity-scope-manpages 3.0+14.04.20140324-0ubuntu3 all Manual pages scope for Unity
ii unity-scope-openclipart 0.1+13.10.20130723-0ubuntu1 all OpenClipArt scope for Unity
ii unity-scope-texdoc 0.1+14.04.20140328-0ubuntu1 all Texdoc scope for Unity
ii unity-scope-tomboy 0.1+13.10.20130723-0ubuntu1 all Tomboy scope for Unity
ii unity-scope-video-remote 0.3.15+16.04.20160212.1-0ubuntu3 amd64 Remote videos engine
ii unity-scope-virtualbox 0.1+13.10.20130723-0ubuntu1 all VirtualBox scope for Unity
ii unity-scope-yelp 0.1+13.10.20130723-0ubuntu1 all Help scope for Unity
ii unity-scope-zotero 0.1+13.10.20130723-0ubuntu1 all Zotero scope for Unity
ii unity-scopes-master-default 6.8.2+16.04.20160212.1-0ubuntu3 all Home scope that aggregates results from multiple scopes
ii unity-scopes-runner 7.1.4+18.04.20180209.1-0ubuntu2 all desktop runner for misceallenous scopes
ii unity-services 7.5.0+18.04.20190304-0ubuntu1 amd64 Services for the Unity interface
ii unity-settings-daemon 15.04.1+18.04.20180413-0ubuntu1.2 amd64 daemon handling the Unity session settings
rc unity-webapps-common 2.4.17+15.10.20150616-0ubuntu2 all Unity WebApp integration scripts
rc unity-webapps-service 2.5.0~+16.04.20160201-0ubuntu1 amd64 Service for Web Apps integration with the Unity desktop
Output of dpkg -l | grep gnome
is:
ii compiz-gnome 1:0.9.13.1+18.04.20180302-0ubuntu1 amd64 OpenGL window and compositing manager - GNOME window decorator
ii gir1.2-gnomebluetooth-1.0:amd64 3.28.0-2ubuntu0.2 amd64 Introspection data for GnomeBluetooth
ii gir1.2-gnomedesktop-3.0:amd64 3.28.2-0ubuntu1.5 amd64 Introspection data for GnomeDesktop
ii gir1.2-gnomekeyring-1.0 3.12.0-1build1 amd64 GNOME keyring services library - introspection data
ii gkbd-capplet 3.26.0-3ubuntu0.18.04.1 amd64 GNOME control center tools for libgnomekbd
ii gnome-accessibility-themes 3.28-1ubuntu1 all High Contrast GTK+ 2 theme and icons
ii gnome-applets 3.28.0-1 amd64 Various applets for the GNOME panel - binary files
ii gnome-applets-data 3.28.0-1 all Various applets for the GNOME panel - data files
ii gnome-backgrounds 3.28.0-1 all Set of backgrounds packaged with the GNOME desktop
ii gnome-bluetooth 3.28.0-2ubuntu0.2 amd64 GNOME Bluetooth tools
ii gnome-calculator 1:3.28.2-1~ubuntu18.04.1 amd64 GNOME desktop calculator
ii gnome-calendar 3.28.2-0ubuntu0.18.04.1 amd64 Calendar application for GNOME
ii gnome-control-center 1:3.28.2-0ubuntu0.18.04.4 amd64 utilities to configure the GNOME desktop
ii gnome-control-center-data 1:3.28.2-0ubuntu0.18.04.4 all configuration applets for GNOME - data files
ii gnome-control-center-faces 1:3.28.2-0ubuntu0.18.04.4 all utilities to configure the GNOME desktop - faces images
ii gnome-desktop3-data 3.28.2-0ubuntu1.5 all Common files for GNOME desktop apps
ii gnome-disk-utility 3.28.3-0ubuntu1~18.04.1 amd64 manage and configure disk drives and media
rc gnome-flashback-common 3.18.2-1ubuntu1 all GNOME Flashback application - common data files
ii gnome-font-viewer 3.28.0-1 amd64 font viewer for GNOME
ii gnome-getting-started-docs 3.28.2-0ubuntu0.1 all Help a new user get started in GNOME
ii gnome-icon-theme 3.12.0-3 all GNOME Desktop icon theme
ii gnome-initial-setup 3.28.0-2ubuntu6.16.04.4 amd64 Initial GNOME system setup helper
ii gnome-keyring 3.28.0.2-1ubuntu1.18.04.1 amd64 GNOME keyring services (daemon and tools)
ii gnome-keyring-pkcs11:amd64 3.28.0.2-1ubuntu1.18.04.1 amd64 GNOME keyring module for the PKCS#11 module loading library
ii gnome-mahjongg 1:3.22.0-3 amd64 classic Eastern tile game for GNOME
ii gnome-menus 3.13.3-11ubuntu1.1 amd64 GNOME implementation of the freedesktop menu specification
ii gnome-mines 1:3.28.0-1ubuntu1 amd64 popular minesweeper puzzle game for GNOME
ii gnome-online-accounts 3.28.0-0ubuntu2.1 amd64 service to manage online accounts for the GNOME desktop
ii gnome-orca 3.28.0-3ubuntu1 all Scriptable screen reader - transitional package
ii gnome-panel 1:3.26.0-1ubuntu5 amd64 launcher and docking facility for GNOME
ii gnome-panel-data 1:3.26.0-1ubuntu5 all common files for the GNOME Panel
ii gnome-power-manager 3.26.0-1 amd64 power management tool for the GNOME desktop
ii gnome-screensaver 3.6.1-8ubuntu3 amd64 GNOME screen saver and locker
ii gnome-screenshot 3.25.0-0ubuntu2 amd64 screenshot application for GNOME
ii gnome-session-bin 3.28.1-0ubuntu3 amd64 GNOME Session Manager - Minimal runtime
ii gnome-session-canberra 0.30-5ubuntu1 amd64 GNOME session log in and log out sound events
ii gnome-session-common 3.28.1-0ubuntu3 all GNOME Session Manager - common files
rc gnome-session-flashback 1:3.18.2-1ubuntu1 all GNOME Session Manager - GNOME Flashback session
ii gnome-settings-daemon 3.28.1-0ubuntu1.3 amd64 daemon handling the GNOME session settings
ii gnome-settings-daemon-schemas 3.28.1-0ubuntu1.3 all Shared schemas for gnome-settings-daemon
ii gnome-shell 3.28.4-0ubuntu18.04.1 amd64 graphical shell for the GNOME desktop
ii gnome-shell-common 3.28.4-0ubuntu18.04.1 all common files for the GNOME graphical shell
ii gnome-shell-extension-appindicator 18.04.1 all App indicators for GNOME Shell
ii gnome-shell-extension-ubuntu-dock 0.9.1ubuntu18.04.3 all Ubuntu Dock for GNOME Shell
rc gnome-software 3.28.1-0ubuntu4.18.04.10 amd64 Software Center for GNOME
ii gnome-software-common 3.28.1-0ubuntu4.18.04.10 all Software Center for GNOME (common files)
ii gnome-startup-applications 3.28.1-0ubuntu3 amd64 Startup Applications manager for GNOME
ii gnome-sudoku 1:3.28.0-1 amd64 Sudoku puzzle game for GNOME
ii gnome-system-log 3.9.90-5 amd64 system log viewer for GNOME
ii gnome-system-monitor 3.28.2-0ubuntu1 amd64 Process viewer and system resource monitor for GNOME
ii gnome-system-tools 3.0.0-6ubuntu1 amd64 Cross-platform configuration utilities for GNOME
ii gnome-terminal 3.28.2-1ubuntu1~18.04.1 amd64 GNOME terminal emulator application
ii gnome-terminal-data 3.28.2-1ubuntu1~18.04.1 all Data files for the GNOME terminal emulator
ii gnome-themes-extra:amd64 3.28-1ubuntu1 amd64 Adwaita GTK+ 2 theme — engine
ii gnome-themes-extra-data 3.28-1ubuntu1 all Adwaita GTK+ 2 theme — common files
ii gnome-todo 3.28.1-1 amd64 minimalistic personal task manager designed to fit GNOME desktop
ii gnome-todo-common 3.28.1-1 all common files for GNOME To Do
ii gnome-tweaks 3.28.1-1 all tool to adjust advanced configuration settings for GNOME
ii gnome-user-docs 3.28.2+git20180715-0ubuntu0.1 all GNOME user's guide
ii gnome-user-guide 3.28.2+git20180715-0ubuntu0.1 all GNOME user's guide - dummy transitional package
rc gnome-user-share 3.18.3-3 amd64 User level public file sharing via WebDAV
ii gnome-video-effects 0.4.3-1ubuntu1 all Collection of GStreamer effects
ii language-pack-gnome-en 1:18.04+20180712 all GNOME translation updates for language English
ii language-pack-gnome-en-base 1:18.04+20180712 all GNOME translations for language English
ii language-selector-gnome 0.188.3 all Language selector for Ubuntu
ii libgnome-autoar-0-0:amd64 0.2.3-1 amd64 Archives integration support for GNOME
ii libgnome-bluetooth13:amd64 3.28.0-2ubuntu0.2 amd64 GNOME Bluetooth tools - support library
ii libgnome-desktop-3-12:amd64 3.18.2-1ubuntu1 amd64 Utility library for loading .desktop files - runtime files
ii libgnome-desktop-3-17:amd64 3.28.2-0ubuntu1.5 amd64 Utility library for loading .desktop files - runtime files
ii libgnome-games-support-1-3:amd64 1.4.1-1 amd64 library for common functions of GNOME games
ii libgnome-games-support-common 1.4.1-1 all library for common functions of GNOME games (common files)
ii libgnome-keyring-common 3.12.0-1build1 all GNOME keyring services library - data files
ii libgnome-keyring0:amd64 3.12.0-1build1 amd64 GNOME keyring services library
ii libgnome-menu-3-0:amd64 3.13.3-11ubuntu1.1 amd64 GNOME implementation of the freedesktop menu specification
ii libgnome-todo 3.28.1-1 amd64 library data for GNOME To Do
ii libgnomekbd-common 3.26.0-3ubuntu0.18.04.1 all GNOME library to manage keyboard configuration - common files
ii libgnomekbd8:amd64 3.26.0-3ubuntu0.18.04.1 amd64 GNOME library to manage keyboard configuration - shared library
ii libpam-gnome-keyring:amd64 3.28.0.2-1ubuntu1.18.04.1 amd64 PAM module to unlock the GNOME keyring upon login
ii libreoffice-gnome 1:6.0.7-0ubuntu0.18.04.8 amd64 office productivity suite -- GNOME integration
ii libsoup-gnome2.4-1:amd64 2.62.1-1ubuntu0.1 amd64 HTTP library implementation in C -- GNOME support library
ii nautilus-extension-gnome-terminal 3.28.2-1ubuntu1~18.04.1 amd64 GNOME terminal emulator application
ii network-manager-gnome 1.8.10-2ubuntu2 amd64 network management framework (GNOME frontend)
ii network-manager-openvpn-gnome 1.8.2-1 amd64 network management framework (OpenVPN plugin GNOME GUI)
ii network-manager-pptp-gnome 1.2.6-1 amd64 network management framework (PPTP plugin GNOME GUI)
ii pinentry-gnome3 1.1.0-1 amd64 GNOME 3 PIN or pass-phrase entry dialog for GnuPG
ii policykit-1-gnome 0.105-6ubuntu2 amd64 authentication agent for PolicyKit
rc system-config-printer-gnome 1.5.7+20160212-0ubuntu2 all Printer configuration GUI
ii thunderbird-gnome-support 1:60.8.0+build1-0ubuntu0.18.04.1 amd64 Email, RSS and newsgroup client - GNOME support
