A slightly changed Redmond layout. Made the panel bigger, customized the clock, removed app shortcuts, added the network monitor applet, changed the mate-menu icon.
The theme is 1976-dark-0.985, the icons theme is FlatWoken.
Here's the custom clock layout:
<big>%H:%M</big>%n<small>%a %e %b, %Y</small>
To change it:
- Open dconf-editor.
- Open org.mate.panel.objects.clock.prefs.
- Manually change the format key to custom.
