My pain is very high.
I have an Android Samsung S-25 fone.
My son-in-law gets my messsages, but he does not get mine.
At one time I blocked his number.
What can I check?
What can I check?
Do you mean he gets your messages but you don't get his?
Is his also an Android phone? If not, maybe you can switch to WhatsApp which makes cross-platform texting easier.
There are 2 ways to block calls:
using an App on your phone, or
using your telephone service provider by adding his number to the list of blocked numbers.
If the latter, you need to contact your provider.
If the first, your App should show the list of blocked numbers and allow you to delete the block.
He got my message.
I appreciate the help here.
You guy and ladies are flexible.
I posted about "God" on another forum and got banned for 3 months.
I love helping people.
I think he has an Apple fone. (Way over priced.)
My daughter said he got my message.
I am good.
I made some paper airplanes for some young children where I live.
