Hi
Anybody has a problem installing/re-installing my-weather-indicator under the new 24.04 LTS ???
Mine works, still works after upgrade. But a friend who just made a fresh install of 24.04 gets a "unable to locate package'
and
Even by downloading the.deb file from Launchpad he gets a
" error dependency is not satisfied girl1.2-webkit2-4.0 "
Help any one ?
W
If one of you guys know how to revive it or point at an alternative way to (re)install it... IT would be very much appreciated.
And I guess I'm not alone
Thx
W
The problem is the PPA does not seem to have been updated to the latest Ubuntu release:
Now, whatever .deb package I want to install I get this (tried through App Center and Terminal and get same):
root@ME:/home/ME# sudo apt install (package name)
E: Conflicting values set for option Signed-By regarding source Index of /atareao/atareao/ubuntu noble: -----BEGIN PGP PUBLIC KEY BLOCK-----
mI0ETQfDgQEEAPSiDI/aHY9bPa1K4pvcMR8g3eJr6/9cdEDihLj0JbMCn8a8rXMi
4iTwvFJJQFUalIzRSc67AUEp9rNQyAHsZFEmxD9Ah+j8eI/ULmMRN/YzHUT3V2vt
W29pxrsz4ZFNQKYENoDoNrY0sCmkNnWk9gXwPKazYVCkTv9fpQdhhIbbABEBAAGw DAAAZ3BnAQAAAAAAALQZTGF1bmNocGFkIFBQQSBmb3IgYXRhcmVhb7AMAABncGcC
AAAAAAAAiLgEEwECACIFAk0Hw4ECGwMGCwkIBwMCBhUIAgkKCwQWAgMBAh4BAheA
AAoJEGqWU/k2/VUpcVED/2hKJXx2WZiTLeUhJUiLWlAFR0eXoFnGXgz3VSnGlLE0
xg8e0NqFzY0/PGQBfqVl6i88wRxNB59AYqnLh2EOYcIM1tiqVY+jI8lCh1xwQAOX uxNDu6vCViVyjMrLSC24UAqTN9yZMBeFbaa1eMi859t0WpDMPTzjVQNHbuQAXyGW
sAYAA2dwZwA=
-----END PGP PUBLIC KEY BLOCK-----
!= -----BEGIN PGP PUBLIC KEY BLOCK-----
W29pxrsz4ZFNQKYENoDoNrY0sCmkNnWk9gXwPKazYVCkTv9fpQdhhIbbABEBAAG0 GUxhdW5jaHBhZCBQUEEgZm9yIGF0YXJlYW+IuAQTAQIAIgUCTQfDgQIbAwYLCQgH
AwIGFQgCCQoLBBYCAwECHgECF4AACgkQapZT+Tb9VSlxUQP/aEolfHZZmJMt5SEl
SItaUAVHR5egWcZeDPdVKcaUsTTGDx7Q2oXNjT88ZAF+pWXqLzzBHE0Hn0BiqcuH YQ5hwgzW2KpVj6MjyUKHXHBAA5e7E0O7q8JWJXKMystILbhQCpM33JkwF4VtprV4
yLzn23RakMw9PONVA0du5ABfIZY=
=8gbf
E: The list of sources could not be read.
Too technical for me
Someone here have an idea what to do ?
Many thanks
W
If you log on as root (# pound sign), you dont need sudo.
No reason to mask, "root@ME:/home/ME# sudo apt "
looks like the hostname is ME, root is the user but the /home/ME does not make sense.
The atareao repository is not working, ip not found.
Understand the sudo thing
But why is it that I get this and installing another .deb doesn't seem to work ?
W
you may have keys that are not needed, sudo apt-key list will show them.
Only one shows as 'expired'
If you have a bad ppa, remove it with sudo add-apt-repository --remove <ppa>
repeat sudo apt update until it is clean.
in my um24.04 I have two keys only.
pub rsa4096 2012-05-11 [SC]
8439 38DF 228D 22F7 B374 2BC0 D94A A3F0 EFE2 1092
uid [ unknown] Ubuntu CD Image Automatic Signing Key (2012) <[email protected]>
/etc/apt/trusted.gpg.d/ubuntu-keyring-2018-archive.gpg
pub rsa4096 2018-09-17 [SC]
F6EC B376 2474 EDA9 D21B 7022 8719 20D1 991B C93C
uid [ unknown] Ubuntu Archive Automatic Signing Key (2018) <[email protected]>
I just wanted to mention that it appears to have been updated and I have it running beautifully on 24.04.1 LTS. It even found my location without me having to fuss about with it like usual, so that's already a tremendous improvement by me.
YAY - FINALLY !!!
I just installed it too - and it works...mostly.
(Getting it to be at my location remains a work in progress.)
Thanks for the update here Bornagainpenguin.
