I had unusual luck today when it became known to me that you musn’t remove anything at all in Ubuntu 16 Mate, I say “luck” because I almost did it myself, and I might not be here if that had happened.
Whenever you try to remove any package you’re told that ubuntu-mate-desktop
, ubuntu-mate-core
or something similar will also be removed.
There’s some threads about this already saying it’s ok if those packages are removed but here’s the catch: when you run something like sudo apt-get autoremove
then a lot of stuff will be removed from the system as well. This “a lot of stuff” is what you see in the Depends
section of apt show ubuntu-mate-desktop
. I bet this will easily break the system.
There seems to be a good reason that things are like this now but most people including myself couldn’t imagine it, and there’s no warning about it
So if you’re wanting to remove any of the programs you don’t want, replace them by your preferred programs, downgrade or things like that, you can’t do it without risking the whole OS
In previous Ubuntu Mate releases you don’t have this problem, e.g. you could uninstall unnecessary software and nothing else just fine.
