Hello all, UM 18.04 - Firefox 61.0.1
Does anyone have the magic (no matter what kind) to install “nautilus-image-converter”?
I have tried to install many many times, to no avail.
Had it in UM 16.04 and used it all the time.
Thanks
Thanks
Please see -
Hi mdooley…
Tried this > sudo apt install caja-image-converter, Still nothing. Oh I did an update to and still nothing.
Now what? Thanks
mt
Hello mdooley, You got the magic touch… When nothing happened I tried the old “Windows reboot after installing anything” trick!
And there it was
Thank You so much
mt
