Hi, I installed the mpd, “Cantata.” I’m at a loss as to configuring it. Specifically, the local host or socket.
Thanks,
Mike
Thanks,
Mike
Solved. I found out I needed to first install mpd. Cantata then allowed me to choose “single user,” and it all went smoothly after that.
