Hi!
What is the permission attribute of a folder or file
for "Read and Write - Access - Access - No Execute (-)" ?
When I done it with chmod 0755 /file or /path
Result with +x :-(, don't want it execute.
So, I don't want that:
Read and Write - Access - Access - Execute (+)
When I use
chmod 0644 ,I got "list, create/delete, no access, - No Execute"
I read about this:
7 – for read, write, and execute permission
6 – for read and write privileges
5 – for read and execute privileges
4 – for read privileges
When i done "chmod 0655 /file" then I got the result:
"Read and write - Read only - Read only - No Execute"
(This is what I want)
when I done "chmod 0655 /path then I got the
result:
List, create/delete, No Access - No Execute
(This is what I don't want)
The "List, create/delete, No Access" is wrong.
I need for folder permissions: Create and delete files - Access - Access - No Execute (-x) permission.
Please help! Thanks!
I hope this helps a bit (anyone correct me if I am wrong):
- "execute" on a directory means you can change into that directory, on a file regular it means "execute the file"
- "read" on a directory means you can read files inside (assuming the files themselves are readable), on a file it obviously means being able to read the file, the "write" permission is analogous
Ok, got it now:
Example:
sudo chmod 0644 /var/log/dmesg
= Read and Write, Read only, Read only, Execute permission is unchecked
sudo chmod 0755 /folder
= Create and delete files, Access files, Access files, -x on Execute permission
S O L V E D
