Need help, wireless issue on Lenovo T61
Hi there,
I recently installed Mate (latest stable release) on an old T61 my parents gave me. Everything has been working great except for one strange issue with the wireless card. The wireless works fine for some period of time after booting up, but then after maybe a day or two it just stops working. It behaves exactly like the card is turned off, but using the wireless power function key doesn't bring it back. I first thought maybe power management was causing some problem, so I set it to only blank the screen. That didn't help, and I never unplug the power cord so I don't think power management is the issue. The amount of time it takes to happen seems to vary from 1 to 3 days and is not consistent. If anyone has some suggestions on things to try, I'm all ears.
Oh, and I also updated the BIOS, with no change.
Here's the output from the system log, grepped for the wireless card driver:
[ 12.633178] iwl3945: Intel(R) PRO/Wireless 3945ABG/BG Network Connection driver for Linux, in-tree:s
[ 12.633181] iwl3945: Copyright(c) 2003-2011 Intel Corporation
[ 12.633400] iwl3945 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 12.688334] iwl3945 0000:03:00.0: Tunable channels: 11 802.11bg, 13 802.11a channels
[ 12.688337] iwl3945 0000:03:00.0: Detected Intel Wireless WiFi Link 3945ABG
[ 12.833469] ieee80211 phy0: Selected rate control algorithm 'iwl-3945-rs'
[ 24.169293] iwl3945 0000:03:00.0: loaded firmware version 15.32.2.9
[62648.492117] iwl3945 0000:03:00.0: Error sending C_POWER_TBL: time out after 500ms.
[62648.492130] iwl3945 0000:03:00.0: set power fail, ret = -110
[62649.396083] iwl3945 0000:03:00.0: Queue 4 stuck for 2500 ms.
[62649.396109] iwl3945 0000:03:00.0: On demand firmware reload
[62649.657906] iwl3945 0000:03:00.0: Microcode SW error detected. Restarting 0x2000008.
[62649.657927] iwl3945 0000:03:00.0: Loaded firmware version: 15.32.2.9
[62649.657965] iwl3945 0000:03:00.0: Start IWL Error Log Dump:
[62649.657971] iwl3945 0000:03:00.0: Status: 0x000302E4, count: 1
[62649.657977] iwl3945 0000:03:00.0: Desc Time asrtPC blink2 ilink1 nmiPC Line
[62649.658209] iwl3945 0000:03:00.0: SYSASSERT (0x5) 0000000024 0x008B6 0x0F3F2 0x0029A 0x00000 947
[62680.172835] iwl3945 0000:03:00.0: Microcode SW error detected. Restarting 0x2000008.
[62680.172864] iwl3945 0000:03:00.0: Loaded firmware version: 15.32.2.9
[62680.172907] iwl3945 0000:03:00.0: Start IWL Error Log Dump:
[62680.172917] iwl3945 0000:03:00.0: Status: 0x000302E4, count: 1
[62680.172926] iwl3945 0000:03:00.0: Desc Time asrtPC blink2 ilink1 nmiPC Line
[62680.173167] iwl3945 0000:03:00.0: SYSASSERT (0x5) 0000000024 0x008B6 0x0F3F2 0x0029A 0x00000 947
[62711.099355] iwl3945 0000:03:00.0: Microcode SW error detected. Restarting 0x2000008.
[62711.099385] iwl3945 0000:03:00.0: Loaded firmware version: 15.32.2.9
[62711.099428] iwl3945 0000:03:00.0: Start IWL Error Log Dump:
[62711.099443] iwl3945 0000:03:00.0: Status: 0x000302E4, count: 1
[62711.099460] iwl3945 0000:03:00.0: Desc Time asrtPC blink2 ilink1 nmiPC Line
[62711.099704] iwl3945 0000:03:00.0: SYSASSERT (0x5) 0000000024 0x008B6 0x0F3F2 0x0029A 0x00000 947
[62742.126707] iwl3945 0000:03:00.0: Microcode SW error detected. Restarting 0x2000008.
[62742.126738] iwl3945 0000:03:00.0: Loaded firmware version: 15.32.2.9
[62742.126780] iwl3945 0000:03:00.0: Start IWL Error Log Dump:
[62742.126790] iwl3945 0000:03:00.0: Status: 0x000302E4, count: 1
[62742.126799] iwl3945 0000:03:00.0: Desc Time asrtPC blink2 ilink1 nmiPC Line
[62742.127041] iwl3945 0000:03:00.0: SYSASSERT (0x5) 0000000024 0x008B6 0x0F3F2 0x0029A 0x00000 947
[62773.153118] iwl3945 0000:03:00.0: Microcode SW error detected. Restarting 0x2000008.
[62773.153149] iwl3945 0000:03:00.0: Loaded firmware version: 15.32.2.9
[62773.153191] iwl3945 0000:03:00.0: Start IWL Error Log Dump:
[62773.153201] iwl3945 0000:03:00.0: Status: 0x000302E4, count: 1
[62773.153211] iwl3945 0000:03:00.0: Desc Time asrtPC blink2 ilink1 nmiPC Line
[62773.153451] iwl3945 0000:03:00.0: SYSASSERT (0x5) 0000000024 0x008B6 0x0F3F2 0x0029A 0x00000 947
[62781.751542] iwl3945 0000:03:00.0: Microcode SW error detected. Restarting 0x2000008.
[62781.751551] iwl3945 0000:03:00.0: Loaded firmware version: 15.32.2.9
[62781.751585] iwl3945 0000:03:00.0: Start IWL Error Log Dump:
[62781.751591] iwl3945 0000:03:00.0: Status: 0x000302E4, count: 1
[62781.751595] iwl3945 0000:03:00.0: Desc Time asrtPC blink2 ilink1 nmiPC Line
[62781.751816] iwl3945 0000:03:00.0: SYSASSERT (0x5) 0000000024 0x008B6 0x0F3F2 0x0029A 0x00000 947
[62817.081786] iwl3945 0000:03:00.0: Microcode SW error detected. Restarting 0x2000008.
[62817.081816] iwl3945 0000:03:00.0: Loaded firmware version: 15.32.2.9
[62817.081859] iwl3945 0000:03:00.0: Start IWL Error Log Dump:
[62817.081869] iwl3945 0000:03:00.0: Status: 0x000302E4, count: 1
[62817.081878] iwl3945 0000:03:00.0: Desc Time asrtPC blink2 ilink1 nmiPC Line
[62817.082118] iwl3945 0000:03:00.0: SYSASSERT (0x5) 0000000024 0x008B6 0x0F3F2 0x0029A 0x00000 947
[215174.492113] iwl3945 0000:03:00.0: Error sending C_POWER_TBL: time out after 500ms.
[215174.492126] iwl3945 0000:03:00.0: set power fail, ret = -110
[215175.348078] iwl3945 0000:03:00.0: Queue 4 stuck for 2500 ms.
[215175.348089] iwl3945 0000:03:00.0: On demand firmware reload
[215175.432307] iwl3945 0000:03:00.0: BSM uCode verification failed at addr 0x00003800+0 (of 900), is 0xa5a5a5a2, s/b 0xf802020
[215175.432312] iwl3945 0000:03:00.0: Unable to set up bootstrap uCode: -5
[215175.479022] iwl3945 0000:03:00.0: BSM uCode verification failed at addr 0x00003800+0 (of 900), is 0xa5a5a5a2, s/b 0xf802020
[215175.479025] iwl3945 0000:03:00.0: Unable to set up bootstrap uCode: -5
[215175.525724] iwl3945 0000:03:00.0: BSM uCode verification failed at addr 0x00003800+0 (of 900), is 0xa5a5a5a2, s/b 0xf802020
[215175.525727] iwl3945 0000:03:00.0: Unable to set up bootstrap uCode: -5
[215175.572437] iwl3945 0000:03:00.0: BSM uCode verification failed at addr 0x00003800+0 (of 900), is 0xa5a5a5a2, s/b 0xf802020
[215175.572440] iwl3945 0000:03:00.0: Unable to set up bootstrap uCode: -5
[215175.619136] iwl3945 0000:03:00.0: BSM uCode verification failed at addr 0x00003800+0 (of 900), is 0xa5a5a5a2, s/b 0xf802020
[215175.619139] iwl3945 0000:03:00.0: Unable to set up bootstrap uCode: -5
[215175.655385] iwl3945 0000:03:00.0: Unable to initialize device after 5 attempts.
[215175.655420] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[215175.655678] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[215175.656396] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[215175.657776] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[215175.659064] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[215175.660667] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[215175.661308] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[215175.661810] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[215175.662246] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_h
[215175.662721] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_h
[215175.663279] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_h
[215175.663719] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_h
[215175.664279] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[215175.664810] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[215175.665331] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[215175.665853] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[215175.666441] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[215175.667157] Modules linked in: cdc_acm ctr ccm nouveau snd_hda_codec_analog arc4 snd_hda_codec_generic iwl3945 iwlegacy coretemp snd_hda_intel mac80211 snd_hda_controller mxm_wmi snd_hda_codec ttm kvm r852 snd_hwdep drm_kms_helper sm_common drm nand cfg80211 snd_pcm nand_ecc pcmcia i2c_algo_bit nand_bch snd_seq_midi bch nand_ids r592 joydev snd_seq_midi_event mtd serio_raw yenta_socket snd_rawmidi thinkpad_acpi snd_seq pcmcia_rsrc memstick pcmcia_core nvram snd_seq_device lpc_ich snd_timer snd shpchp wmi soundcore 8250_fintek video mac_hid parport_pc ppdev lp parport autofs4 psmouse sdhci_pci firewire_ohci sdhci firewire_core crc_itu_t pata_acpi e1000e ptp pps_core
[244575.060688] iwl3945 0000:03:00.0: BSM uCode verification failed at addr 0x00003800+0 (of 900), is 0xa5a5a5a2, s/b 0xf802020
[244575.060693] iwl3945 0000:03:00.0: Unable to set up bootstrap uCode: -5
[244575.107396] iwl3945 0000:03:00.0: BSM uCode verification failed at addr 0x00003800+0 (of 900), is 0xa5a5a5a2, s/b 0xf802020
[244575.107399] iwl3945 0000:03:00.0: Unable to set up bootstrap uCode: -5
[244575.154102] iwl3945 0000:03:00.0: BSM uCode verification failed at addr 0x00003800+0 (of 900), is 0xa5a5a5a2, s/b 0xf802020
[244575.154105] iwl3945 0000:03:00.0: Unable to set up bootstrap uCode: -5
[244575.200805] iwl3945 0000:03:00.0: BSM uCode verification failed at addr 0x00003800+0 (of 900), is 0xa5a5a5a2, s/b 0xf802020
[244575.200808] iwl3945 0000:03:00.0: Unable to set up bootstrap uCode: -5
[244575.247517] iwl3945 0000:03:00.0: BSM uCode verification failed at addr 0x00003800+0 (of 900), is 0xa5a5a5a2, s/b 0xf802020
[244575.247520] iwl3945 0000:03:00.0: Unable to set up bootstrap uCode: -5
[244575.283698] iwl3945 0000:03:00.0: Unable to initialize device after 5 attempts.
Thanks
C|
