Installed Mate for Pi2 today. Everything is working. Great. Except the micro SD
card is unallocated totally.
I looked at the re-sizing commands:
Re-size file system
There are no utilities included for automatic file system re-sizing. However, it’s not hard to do manually. Once booted:
sudo fdisk /dev/mmcblk0
Delete the second partition (d, 2), then re-create it using the defaults (n, p, 2, enter, enter), then write and exit (w). Reboot the system, then:
sudo resize2fs /dev/mmcblk0p2
I am sorry, I do not understand them. fdisk does not provide a partition table.
Is (d, 2) a command? When do I enter it with parentheses or without? What is the command syntax to re-create the second partition?
