Hello, My Samsung Printer M2835DW/ZAA works fine with the xorg? drivers. The ones that Ubuntu installs when the printer is added. All is wonderful and works till there is a power outage. It’s only for a split second, and then the power is restored. The Printers little blue light comes on but, anything I try to print after the power fails, gets stuck in the Printer Queue. Also none of the buttons work on top of the Printer. I have the M2835DW set up using the USB only.
I go to Printer properties, and I can’t release it to be printed. I have to delete the print job. To get the Printer to work, I have to delete the M2835DW icon, and unplug the printer power…wait…plug it back in then wait for the M2835DW to be found, and it then works.
I was thinking that if I used the Samsung Unified Drivers that it would just work with less issues.
The Samsung Printer M2835DW/XAA has Linux Support. That"s why I bought it. I just don’t want to mess things up trying to install the drivers using the tar ball.
Thank You
