Hey
Does anyone have specific instructions on how to build the kernel on Raspberry Pi using 64-bit MATE distribution?
I have Ubuntu MATE 18.04 installed on Pi B+, using standard Ubuntu kernel build flow seems to fail.
Thank you
Hey
Thank you
Have never done this myself, but now I'm getting curious as you and others suggest that this is quite different from the steps to cross-compile a Raspbian kernel.
@jimmers I am assuming you meant a Pi 3B+, as a Pi B+ does not support 64-bit.
