On another PC running Mate 20.04, the network animation shows a WIFI animation instead of an Ethernet animation. Personally I do not really care for this, but in the progress of making UM better it should be fixed imo.
How to reproduce:
Disable WIFI
Plug in an Ethernet cable.
You will see the animation is for WIFI, not Ethernet.
Now I would have uploaded an recording I made (70kb)
How do I attach files like e.g. a mkv or a zip ?
Hi Guy,
You can follow this commands to reinstall network and indicators: sudo apt-get install --reinstall network-manager network-manager-gnome indicator-applet indicator-network
Reboot and try if works. If not: sudo /etc/init.d/network-manager stop sudo rm /var/lib/NetworkManager/NetworkManager.state sudo /etc/init.d/network-manager start
Do somebody saw this issue before 20.04 ? Maybe we need to open a bug report.
Personally, this is not enough for my eyes to spot it and be disturbed with, but can be a nice improvement @Guy, you can report it as bug, to get it fixed in next releases
