Have you guys had the network manager issue with wifi on 17.04 like we have on 16.04 ?
Sorry should have specified a bit more… the bug that after suspending and “waking up” the computer the network manager shows the “up and down arrows” instead of the usual wifi symbol and doesnt show you any available wifi networks ( all this while the wifi might still work and give you connection )
From what I understand the “up and down arrows” mean wired connection.
And this happens when we are definetly not connected to wired, only to wifi
only workarround I know of is to run this command: sudo service network-manager restart
If I’m hitting on the right bug, its still a work in progress.
https://bugs.launchpad.net/ubuntu/+source/network-manager/+bug/1594715
There were lots of (over 300) bugs raised about the wifi issues. The last issue was resuming wifi after coming out of suspend, which I believe is noe resolved.
