Hi!
I am using:
UM 24.10
Kernel 6.11.0-9
Mate 1.26.2
I got an update notice for a new kernel. I triggered the update.
When rebooting under the new kernel It says:
'cryptsetup: Waiting for encrypted source device...'
then I get dropped to shell
So I rebooted under the previous 6.11.0-9 kernel so I can work
trying to force reinstall the new kernel doesn't solve the issue
So...
I tried this: 'sudo aptitude -f install'
And I get this:
Summary:
Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 1
2 not fully installed or removed.
Space needed: 0 B / 356 GB available
Setting up linux-image-unsigned-6.12.3-061203-generic (6.12.3-061203.202412060638) ...
Setting up linux-headers-6.12.3-061203-generic (6.12.3-061203.202412060638) ...
/etc/kernel/header_postinst.d/dkms:
- dkms: running auto installation service for kernel 6.12.3-061203-generic
Sign command: /usr/bin/kmodsign
Signing key: /var/lib/shim-signed/mok/MOK.priv
Public certificate (MOK): /var/lib/shim-signed/mok/MOK.der
Building module:
Cleaning build area...
'make' -j8 KLIB=/lib/modules/6.12.3-061203-generic KLIB_BUILD=/lib/modules/6.12.3-061203-generic/build....(bad exit status: 2)
ERROR (dkms apport): kernel package linux-headers-6.12.3-061203-generic is not supported
Error! Bad return status for module build on kernel: 6.12.3-061203-generic (x86_64)
Consult /var/lib/dkms/backport-iwlwifi/0~89.12325-git36c5be1a/build/make.log for more information.
dkms autoinstall on 6.12.3-061203-generic/x86_64 failed for backport-iwlwifi(10)
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
- dkms: autoinstall for kernel 6.12.3-061203-generic
...fail!
run-parts: /etc/kernel/header_postinst.d/dkms exited with return code 11
dpkg: error processing package linux-headers-6.12.3-061203-generic (--configure):
installed linux-headers-6.12.3-061203-generic package post-installation script
subprocess returned error exit status 11
Processing triggers for linux-image-unsigned-6.12.3-061203-generic (6.12.3-06120 3.202412060638) ...
/etc/kernel/postinst.d/dkms:
Building module:
upported
64)
more information.
...fail!
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11
dpkg: error processing package linux-image-unsigned-6.12.3-061203-generic (--con
figure):
installed linux-image-unsigned-6.12.3-061203-generic package post-installation
script subprocess returned error exit status 11
Errors were encountered while processing:
Error: Sub-process /usr/bin/dpkg returned an error code (1)
W
Find anything in there ^ ?
Right in the first lines I see this warning:
DKMS make.log for backport-iwlwifi-0~89.12325-git36c5be1a for kernel 6.12.3-061203-generic (x86_64)
Fri 13 Dec 20:54:06 EST 2024
Generating local configuration database from kernel ... done.
cc -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -c -o conf.o conf.c
cc -Wall -Wmissing-prototypes -Wstrict-prototypes -O2 -fomit-frame-pointer -c -o zconf.tab.o zconf.tab.c
cc conf.o zconf.tab.o -o conf
#configuration written to .config
make[5]: 'conf' is up to date.
Building backport-include/backport/autoconf.h ... done.
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc-14 (Ubuntu 14.2.0-4ubuntu2) 14.2.0
You are using: gcc-14 (Ubuntu 14.2.0-4ubuntu2) 14.2.0
Over 224 lines in total. In some of them the lines end with either 'Error 1' or 'Error 2' (I humbly have no idea of implication)
W
Just tonight something called 'Berkekey 5.6'...something
Tried to instanl as an update. Connected to kernel 6.12.3
Something failed.
W
I've never attempted to install something like a mainline kernel (or non-distro kernel packages), let alone had it fail. So I am stabbing in the dark.
It looks like when you attempted to install the kernel (module) package, it has failed to build a backported iwlwifi (DKMS) module. I have no idea what the consequences are when a DKMS fails to build during this process; but maybe this is causing some later post-installation step to be skipped; hence the failure to boot.
I'd guess that that bug fix is not related, because it doesn't look related to build failures.
I'm a little curious as to why a 'backported' iwlwifi module is in play at all for such a new kernel and system (24.10).
If you're puzzled... I'm lost
W
What's the output of apt list --installed *iwlwifi*?
apt list --installed iwlwifi
backport-iwlwifi-dkms/oracular,now 1:0~89.12325-git36c5be1a-0ubuntu1 all [installed]
linux-modules-iwlwifi-6.11.0-12-generic/oracular-updates,oracular-security,now 6.11.0-12.13 amd64 [installed,automatic]
linux-modules-iwlwifi-6.11.0-9-generic/oracular-updates,now 6.11.0-9.9 amd64 [installed,automatic]
linux-modules-iwlwifi-generic/oracular-updates,oracular-security,now 6.11.0-12.13 amd64 [installed]
W
Software Updater just triggered this:
I accepted and got this:
but apt list --installed iwlwifi gives me this:
linux-modules-iwlwifi-6.11.0-12-generic/oracular-updates,oracular-security,now 6.11.0-12.13 amd64 [installed,auto-removable]
linux-modules-iwlwifi-6.11.0-13-generic/oracular-updates,now 6.11.0-13.14 amd64 [installed,automatic]
linux-modules-iwlwifi-generic/oracular-updates,now 6.11.0-13.14 amd64 [installed]
Moments ago I got a notification to restart my system for use of new software version... not knowing which it was related to. SO I did restart.
Given it goes to 6.12 first, I got this
I rebooted and tried with 6.11.0-13 and got
So I rebooted with 6.11.0-9, which works
The first two has install problems (even though I was simply activating the 'Software Updater')
This is too far away from what I can understand
W
So 6.11.0-13 is not working?
No or partly. It lead to the screen waiting for the encrypted device.
I guess I'm better (for now) to remove these two that have problems.
Advice ?
'dpkg -l | grep linux-image' get me this:
rc linux-image-6.11.0-12-generic 6.11.0-12.13 amd64 Signed kernel image generic
ii linux-image-6.11.0-13-generic 6.11.0-13.14 amd64 Signed kernel image generic
rc linux-image-6.11.0-8-generic 6.11.0-8.8 amd64 Signed kernel image generic
ii linux-image-6.11.0-9-generic 6.11.0-9.9 amd64 Signed kernel image generic
iF linux-image-unsigned-6.12.3-061203-generic 6.12.3-061203.202412060638 amd64 Linux kernel image for version 6.12.3 on 64 bit x86 SMP
W
p.s. by the way the Software Updater was indicating that 6.11.0-8.8 was flushed, given the updates... and I see it here.
I figured that "ii" stands for "installed, and successfully installed/configured." and that "rc" stands for "removed, but the configuration files are still present."
As a hail mary ... trysudo update-initramfs -u -k all.
Do you know if you need the backports iwlwifi dkms for your wifi? It's not always necessary on newer kernels. Obviously, if removing it disables your wifi, then that's not going to be a solution.
With: sudo update-initramfs -u -k all
I got this:
update-initramfs: Generating /boot/initrd.img-6.11.0-13-generic
update-initramfs: Generating /boot/initrd.img-6.11.0-9-generic
So I guess it seems having worked for these two
W
I guess it does, if the whole exchange I got here (UM 24.10 no wifi) is of any indication
W
Right, I remember that issue. So the backport solved the wifi problems you were having?
Frankly, no idea what solved it, since it apparently solved itself by one of the random pushed updates... But I do connect as usual now, yes.
W
From the previous issue, it looks like you have: Intel Wi-Fi 6 AX201. That has been supported in the kernel since 5.2 (see https://www.intel.com/content/www/us/en/support/articles/000005511/wireless.html).
I would suggest removing the backport; especially as that module failed to build.
Of course, if the wifi drops out again ... then we're really stuck!
