NFS shared setup help
Hi there,
Can anyone help me with NFS connections? I’m trying to connect my local desktop and laptop together. Thanks,
Are both Linux? What Have you done till now?
https://help.ubuntu.com/14.04/serverguide/network-file-system.html
Yes, they are. And to make simpler, both run the latest MATE.
Tx SFromley, how do edit a config file? I guess it has to be done from the terminal.
“gksudo pluma /path/to/config.file” should open the config file as root. And yes, from the terminal.
Thanks, I didn’t gksudo.
