I can have audio using omxplayer, but other than that, my pi 3 is silent.
I tried to look up online and I think using sudo amixer cset numid=3 1
would solve my issue. However, when I used this command, amixer: Control default open error: No such file or directory
showed up. I tried to look for a solution to this online but I couldn’t find one.
I constantly update and upgrade and also update the raspberry kernel so my distribution should be up to date. So what can be a solution to my problem, to let me play videos on youtube with audio? Also, I prefer using the audio jack but for now, neither audio jack nor hdmi outputs audio.
There is another problem: I saw that I can select OpenMax IL in VLC to enable hardware acceleration but I cannot see the option under the instructed Tools -> Preferences -> Video
. Why is that?
Thank you!
