In 16.04 you can sample an audio file by simply hovering the mouse over the file. That does not work for me in 18.04 even though I have Preview Sound Files set to always.
See here: ![]()
Thanks. Worked perfectly. Just embarrassed solution was already in this forum when I asked.
Same problem, installed gstreamer as suggested and works perfectly, too.
Thanks to gadbud for sending me here
