i upgraded from Ubuntu 15.10 Wily to the 16.04 LTS that was offered by my ‘software updater’ . Everything seemed to go fine. Then when it was finished with the rather long upgrade it restarted my computer. Now my computer only loads the Ubuntu Mate desktop background image and nothing else. I can’t use the Ctrl+Alt+T to drop into terminal…don’t have any control over the computer.
I'm not sure what you mean here. The panels appeared, but are not functioning?
If you open MATE Terminal from the console:
env DISPLAY=:0 mate-terminal
Then switch back with CTRL+ALT+F7... use the terminal to try loading the panels:
mate-panel --replace
This might print out any errors to give a clue why the panels are not loading.
I would guess it's most likely due to a configuration error in your home folder. If you don't mind losing some configuration (e.g. bookmarks, web browser stuff, preferences for programs), I'd suggest creating a new user account and transferring your personal files.
From a terminal, this is the command for the Users & Groups window:
users-admin
To log out:
mate-session-save --logout
If a new user (or guest session) does not work, then this is definitely a system-wide problem. It may be possible to re-install the panels if this is the case:
(nautilus:2796): Gtk-WARNING **: Failed to register client: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
** (mate-panel:2694): WARNING **: Could not connect to session manager: Could not get owner of name 'org.gnome.SessionManager': no such name
(mate-panel:2694): GLib-GObject-CRITICAL **: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
fixme:iphlpapi:NotifyAddrChange (Handle 0x103e368, overlapped 0x103e380): stub
fixme:iphlpapi:NotifyAddrChange (Handle 0x10fe8a0, overlapped 0x10fe8ac): stub
fixme:event:wait_for_withdrawn_state window 0x20062/2a00001 wait timed out
nm-applet-Message: using fallback from indicator to GtkStatusIcon
/usr/lib/python2.7/dist-packages/gi/overrides/Gtk.py:50: RuntimeWarning: You have imported the Gtk 2.0 module. Because Gtk 2.0 was not designed for use with introspection some of the interfaces and API will fail. As such this is not supported by the pygobject development team and we encourage you to port your app to Gtk 3 or greater. PyGTK is the recomended python module to use with Gtk 2.0
warnings.warn(warn_msg, RuntimeWarning)
** Message: Initializing gksu extension...
** (caja:1614): CRITICAL **: caja_menu_provider_get_background_items: assertion 'CAJA_IS_MENU_PROVIDER (provider)' failed
sys:1: Warning: /build/glib2.0-meArNm/glib2.0-2.46.2/./gobject/gsignal.c:2634: instance '0x2536960' has no handler with id '7008'
sys:1: Warning: /build/glib2.0-meArNm/glib2.0-2.46.2/./gobject/gsignal.c:2634: instance '0x25c6780' has no handler with id '6828'
sys:1: Warning: /build/glib2.0-meArNm/glib2.0-2.46.2/./gobject/gsignal.c:2634: instance '0x2496520' has no handler with id '6835'
sys:1: Warning: /build/glib2.0-meArNm/glib2.0-2.46.2/./gobject/gsignal.c:2634: instance '0x2304560' has no handler with id '6842'
sys:1: Warning: /build/glib2.0-meArNm/glib2.0-2.46.2/./gobject/gsignal.c:2634: instance '0x21a8300' has no handler with id '6849'
(caja:1614): Gdk-WARNING **: /build/gtk+2.0-gl_hAC/gtk+2.0-2.24.28/gdk/x11/gdkproperty-x11.c:325 invalid X atom: 1869621875
I did the upgrade again but with one difference…the first time when it asked me if i wanted to remove outdated packages i said ‘no’, but this time i said ‘yes’. That was it…works like a charm now. Those packages must have conflicted with the upgraded system.
Sometimes when updating you will be asked if you want to replace an existing file with a new one, the normal default action is to say no, I on the other hand find it better to install the new one, you must decide yourself whether or not you wish to do the same, I recommend replacing the existing file with the new one!!. (Use at your own risk but I have never had a problem doing just that!.)
