On 16.10 I’ve noticed that there’s no warning when I close a terminal window (or tab) with a running process. For example, run top
and then close the window — it just closes.
I installed and ran gnome-terminal
and again started top
. When I try to close the window it opens a dialog warning about killing the process: “Close this terminal? / There is still a process running in this terminal. Closing the terminal will kill it.”
I made a new user to make sure it wasn’t a setting I messed up, but it’s the same. Again, this is on 16.10. I can test 16.04 at work tomorrow.
Can anyone confirm this before I report the bug?
