Decided to try out ubuntu mate as I have heard lots of good things.
I was using mint mate 17.3. My wifi card is a qualcomm atheros card and will
not show up by default. I used the following site to get it working with mint, but it wont work for ubuntu mate.
I get the following error. Hope someone can help me figure this out.
"Reading database … 227308 files and directories currently installed.)
Preparing to unpack backath10k-dkms_2.0_all.deb …
Deleting module version: 2.0
completely from the DKMS tree.
Done.
Unpacking backath10k-dkms (2.0) over (2.0) …
Setting up backath10k-dkms (2.0) …
Loading new backath10k-2.0 DKMS files…
First Installation: checking all kernels…
Building only for 4.4.0-18-generic
Building for architecture x86_64
Building initial module for 4.4.0-18-generic
ERROR: Cannot create report: [Errno 17] File exists: ‘/var/crash/backath10k-dkms.0.crash’
Error! Bad return status for module build on kernel: 4.4.0-18-generic (x86_64)
Consult /var/lib/dkms/backath10k/2.0/build/make.log for more information."
The /var/lib/dkms/back---- is
DKMS make.log for backath10k-2.0 for kernel 4.4.0-18-generic (x86_64)
Sat Apr 9 16:57:05 EDT 2016
make -C /lib/modules/4.4.0-18-generic/build M=/var/lib/dkms/backath10k/2.0/build/driver modules
make[1]: warning: jobserver unavailable: using -j1. Add ‘+’ to parent make rule.
make[1]: Entering directory ‘/usr/src/linux-headers-4.4.0-18-generic’
CC [M] /var/lib/dkms/backath10k/2.0/build/driver/compat/main.o
CC [M] /var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.0.o
CC [M] /var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.1.o
CC [M] /var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.o
/var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.c:14:28: error: static declaration of ‘scatterwalk_ffwd’ follows non-static declaration
static struct scatterlist *scatterwalk_ffwd(struct scatterlist dst[2],
In file included from /var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.c:11:0:
include/crypto/scatterwalk.h:97:21: note: previous declaration of ‘scatterwalk_ffwd’ was here
/var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.c:42:14: error: redefinition of ‘crypto_aead_reqsize’
unsigned int crypto_aead_reqsize(struct crypto_aead *tfm)
In file included from /var/lib/dkms/backath10k/2.0/build/driver/backport-include/crypto/aead.h:3:0,
from /var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.c:12:
include/crypto/aead.h:379:28: note: previous definition of ‘crypto_aead_reqsize’ was here
static inline unsigned int crypto_aead_reqsize(struct crypto_aead *tfm)
/var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.c: In function ‘crypto_aead_reqsize’:
/var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.c:44:9: error: implicit declaration of function ‘crypto_aead_crt’ [-Werror=implicit-function-declaration]
return crypto_aead_crt(tfm)->reqsize + sizeof(struct aead_old_request);
/var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.c:44:29: error: invalid type argument of ‘->’ (have ‘int’)
/var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.c: In function ‘crypto_backport_convert’:
/var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.c:50:34: error: implicit declaration of function ‘aead_request_ctx’ [-Werror=implicit-function-declaration]
struct aead_old_request *nreq = aead_request_ctx(req);
/var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.c:50:34: warning: initialization makes pointer from integer without a cast [-Wint-conversion]
/var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.c:59:43: error: implicit declaration of function ‘aead_request_flags’ [-Werror=implicit-function-declaration]
aead_request_set_callback(&nreq->subreq, aead_request_flags(req),
/var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.c:63:2: error: implicit declaration of function ‘aead_request_set_assoc’ [-Werror=implicit-function-declaration]
aead_request_set_assoc(&nreq->subreq, req->src, req->assoclen);
/var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.c:45:1: warning: control reaches end of non-void function [-Wreturn-type]
cc1: some warnings being treated as errors
scripts/Makefile.build:258: recipe for target ‘/var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.o’ failed
make[3]: *** [/var/lib/dkms/backath10k/2.0/build/driver/compat/backport-4.2.o] Error 1
scripts/Makefile.build:403: recipe for target ‘/var/lib/dkms/backath10k/2.0/build/driver/compat’ failed
make[2]: *** [/var/lib/dkms/backath10k/2.0/build/driver/compat] Error 2
Makefile:1396: recipe for target ‘module/var/lib/dkms/backath10k/2.0/build/driver’ failed
make[1]: *** [module/var/lib/dkms/backath10k/2.0/build/driver] Error 2
make[1]: Leaving directory ‘/usr/src/linux-headers-4.4.0-18-generic’
Makefile:15: recipe for target ‘all’ failed
make: *** [all] Error 2
