This is not a bug report – as others are able to boot using the Beta without issues …
I’m running both Ubuntu 17.10 Mate 64-bit and Mint 18.3 64-bit on my desktop, so I thought it would be no problems to create boot media using the current 18.04 Mate and boot from that to check it out – but that is not happening.
When I boot from the USB stick, I get the MATE symbol, the dots, the screen clears, I get a brief flash of text (too fast to read) and then a black screen with a mouse cursor.
I read a thread on the Ubuntu forums about 18.04 taking several minutes to boot – but I waited ten minutes and still just a mouse cursor.
So, I though I would try various kernel parms using the following process …
Pressing SHIFT while booting brings up a menu, then pressing F6 opens up an editor on the kernel parms line.
I tried selecting only NOMODESET – same result
In desperation, I also tried acpi_os-Linux and acpi_backlight=vendor – same result
I am running an AMD R7 240 video card and it works fine in Ubuntu Mate 17.10 and Mint 18.3 – but that is an older kernel version because I think it’s based off 17.04, not 17.10.
My guess is that Wayland is being used to boot instead of Xorg – but the workaround I found involved editing a conf file that is not present on the boot USB filesystem, so I don’t know how to work around this problem.
And, I ran the sha256sum cmd and confirmed the checksum of the ISO download.
Anything I can try (other than waiting for the release?)
