Hi
I got a Dell Laptop dual booting Windows 10 (for the family) and Ubuntu Mate 16.04 LTS for me.
I am having trouble running VirtualBox.
I have installed it and it seems to be OK.
But when I try to start a virtual machine I get this error;
RTR3InitEx failed with rc=-1912 (rc=-1912)
The VirtualBox kernel modules do not match this version of VirtualBox. The installation of VirtualBox was apparently not successful. Executing
‘/sbin/vboxconfig’
may correct this. Make sure that you do not mix the OSE version and the PUEL version of VirtualBox.
where: supR3HardenedMainInitRuntime what: 4 VERR_VM_DRIVER_VERSION_MISMATCH (-1912) - The installed support driver doesn’t match the version of the user
I suspected that it was the UEFI, but I have tried to disable this, with no result.
I can add, thst I tried to install VirtualBox on the Windows 10, and it work there?
I have tried several commendline commands I found on DuckduckGo, but with no luck.
Does anyone know what to do?
Best regards
Sandersson
