Hi, recently installed 22.04 with 22.04.2 ISO and am at UM 22.04.3. Was doing an interim backup to my three removable (nfts formatted, special use) drives.
Seemed to be quicker (no scientific evidence on timing, just perceived) and in terminal checked and am now using ntfs3 instead of fuseblk (ntfs-3g) on all my removable drives. Had looked into it and was unable to find if one needed to reformat drive to use or needed to configure to use. Seems to work. Can not say whether it is good or bad, just pointing out. Original showed fuseblk.
Did nothing and it showed up.
Wow! tnx for mentioning it! It works here too..... I didn't even notice
