Hi all,
the title says it all “Number block not working at log in screen”.
When trying to type my PW at the log on screen, the number block simply won’t work. Typing from the normal numbers does!.
Any hope of a fix please?.
Hi all,
I’m guessing you mean the numeric keypad on the right side. Is NUM lock definitely switched on?
Yes!, and yes it is switched on.
This is still not working!.
