I’m having problems upgrading libjepg8. Apparently thers a file that is used by another package that is causing it to error out. I have tried any number of combinations of force instal and dpkg, to no avail. Here’s what it’s telling me:
[CODE] wolf@wolf-media:~$ sudo apt list --upgradeable
Listing… Done
libjpeg8/oldstable 8d-1+deb7u1 armhf [upgradable from: 8c-2ubuntu8]
N: There is 1 additional version. Please use the ‘-a’ switch to see it
wolf@wolf-media:~$ sudo apt list --upgradeable -a
Listing… Done
libjpeg8/xenial,xenial,now 8c-2ubuntu8 armhf [installed,upgradable to: 8d-1+deb7u1]
wolf@wolf-media:~$ sudo apt upgrade
Reading package lists… Done
Building dependency tree
Reading state information… Done
Calculating upgrade… Done
The following packages will be upgraded:
libjpeg8
The following packages will be DOWNGRADED:
smplayer-skins
1 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
Need to get 360 kB of archives.
After this operation, 239 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.raspbian.org/raspbian wheezy/main armhf libjpeg8 armhf 8d-1+deb7u1 [132 kB]
Get:2 http://ppa.launchpad.net/ubuntu-pi-flavour-makers/ppa/ubuntu xenial/main armhf smplayer-skins all 2:15.2.0-1~xenial1 [229 kB]
Fetched 360 kB in 2s (159 kB/s)
(Reading database … 175902 files and directories currently installed.)
Preparing to unpack …/libjpeg8_8d-1+deb7u1_armhf.deb …
Unpacking libjpeg8:armhf (8d-1+deb7u1) over (8c-2ubuntu8) …
dpkg: error processing archive /var/cache/apt/archives/libjpeg8_8d-1+deb7u1_armhf.deb (–unpack):
trying to overwrite ‘/usr/lib/arm-linux-gnueabihf/libjpeg.so.8’, which is also in package libjpeg-turbo8:armhf 1.4.2-0ubuntu3
Preparing to unpack …/smplayer-skins_2%3a15.2.0-1~xenial1_all.deb …
Unpacking smplayer-skins (2:15.2.0-1~xenial1) over (2:15.2.0-1~xenial1) …
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)[/CODE]
I’m running 16.04.2 on a raspi 3.
