For over a month with apt update
I have the option to upgrade these packages.
However when using the Software Updater I do not get such a prompt.
I attach the software updater settings:
I am aware of the "phasing of stable release upgrades" but this has taken too long.
Hi
Do you mean that up-gradable software differ between apt update command result and the GUI updater ?
Hello
I mean that when I use the GUI Software Updater I get no prompt to update any package and when I type at the terminal apt update
I am asked whether I want to update the mentioned packages.
