I love the Papirus-GTK icons for my MATE 16.10 desktop, which I installed using the “install-papirus-home-gtk.sh” script from the Papirus github page. There’s also an “install-papirus-root.sh” script that (I think) is supposed to allow the panel icons to be changed, but simply executing the script doesn’t seem to change anything. Are there other system files that need to be altered to allow these icons to be changed? Any help is appreciated, since there isn’t much info on these icons on the web, and I couldn’t find any help at all on changing Ubuntu panel icons.
Hi @delta1071,
try looking on the Mate forum website, it is currently down but I assume it is still working?:
Ok Wolfman. Will do. Thanks for the suggestion.
Yep wolfman, it is down. I’ll keep checking back there occasionally.
Regards,
Steve
Hi Steve,
I posted this and if you read @antechdesigns link, it does kinda explain a few things!.
