hi!
i'm using ubuntu mate @ pi2 for several days , it's pretty cool
and there is a problem i'm asking for help:
the sound playing is not fluent ,always stuck actully when i'm playing mp3 with vlc (using default snd device: bcm2835 alsa)
is there any good solutions?
@yun Have you tried using omxplayer
? VLC is not yet fully compatible with the Raspberry Pi…
hi rohithmadhavan !
omxplayer is fine…anyway
maybe they guys writing the imperfect snd driver on purposely… i’m wondering about that
if you know the real reason,please tell me : )
i’m going to buy a usb sound card to fix it if there is no perfect solutions eventually!
[First - I have Mate on a Pi 2 and its wonderful. A few issues, but on the whole it’s the best!]
I had this problem at first even though it worked perfectly on Raspian both HDMI and with an external speaker. What I found was when I moved the volume control, it would play, then die crackling away. It sounded like a dusty volume control on an old radio. Oddly the more I did it, the longer it cleared up, and oddly enough now works perfectly for both audio and video. I know it sounds weird, but if I had to speculate it may have been a buffering or cache issue?
Another thing to check is did you resize the boot partition to it’s maximum size, and do you have a fast enough chip. Mine is a 16G Ultra (HC1) chip.
hi! i had met some situations just like yours,but unfortunately,without the luck you have
i had been solved this problem with a no more than 1$ CM108-usb-sound card,and it works perfect anyway
so i think it is that the original snd driver’s fault…
