I do have this warning from apt (apt update) and in this case it concerns Playonlinux :
Signature by key 74F7358425EEB6176094C884E0F72778C4676186 uses weak digest algorithm (SHA1)
http://deb.playonlinux.com/dists/trusty/InRelease
removing reinstalling playonlinux from boutique or apt does the same.
Did you noticed ?
Some issues from Google : https://www.google.fr/search?client=ubuntu&channel=fs&q=Signature+by+key+uses+weak+digest+algorithm+(SHA1)&ie=utf-8&oe=utf-8&gfe_rd=cr&ei=tBT-WIiZEM7DaPr-peAM
What i understood : This is a normal APT behaviour, until you can update packages. That seems to belongs to maintainers. Am i right ?
Thanks
