Thanks for the reply & the giggles Aus9 !!
This part:
"Experienced terminal users "
Got me giggling !!
This is because I was a pre-DOS computer user who actively resisted the entire GUI thing for YEARS after win-doze 1.0 so bafflingly appeared.
(And yes - I was also a CLI-only Linux user whilst enjoying its evolutions to a more 'modern' status.)
So - YES - the terminal is just fine by me - and YES - copy/paste DOES work remotely from my desktop to his & vice-versa.
What I've been needing here the most is enough time & energy with a clear head - not so easy to have when one has a high fever & respiratory distress in progress as has been the deal for ~2 weeks for me - so:
Thanks for your patient replies to me during this struggle which is now close to being over.
Now - that's enough about THAT, thanks.
When I said that I use the distant PC just as if I am at that desk - it is a 100% accurate statement with the ONLY exception of not being there in person to go see & touch the printer in the other room.
Now, having some time to recover from almost 2 weeks of illness & having a clearer head - some very related thoughts have occurred to me which cast this discussion into a slightly different light, I think:
1 - There is a 2nd (HP) printer which is reached via its IP address on that same LAN which was discovered & installed from that same Linux desktop PC very easily & immediately at the start of all this - and which has been working flawlessly via LAN since day 1;
2 - The Canon printer has responded to print jobs sent to it after my initial tries to get it driven correctly - but only as if it had been sent mal-formed commands.
It has responded by entering a halted error state - which has required someone there to physically press buttons on it to clear that state.
This seems to tell me that it is already reachable, but that NOT having the correct driver was most likely what caused that halting error response.
3 - Avahi or none, those 2 facts above seem to point more clearly at the nature of the problem as being driver related - would you agree ??
4 - The driver I used before was a PPD IIRC, but now it has been weeks since & my notes are just not clear enough for me to be 100% sure of that.
A bit later tonight I will work at muddling through all the various suggestions from this VERY comprehensive thread, hopefully doing a bit better at NOT repeating any mis-steps of my own, AND:
When next there is a body physically present at his office (monday here in the US, most likely) I will re-test by sending print jobs to that LAN connected Canon printer to see if it works any better.
Again, my thanks for your patience here !!
