OK so I installed Ubuntu MATE again so I can play some games.
I love Papirus Dark icons. And I love the Advanced MATE menu.
When I had gnome icons I would change the advanced menu panel icon by editing the file located at /usr/share/icons/gnome/22x22/start-here.svg or something along those lines.
Now what file do I replace to edit the icon that looks like that 9 square dots that Papirus uses as the default Advanced Menu Icon?
Thanks. I found it. You can say it was a pale ale post. Forgot until my I checked my email.
The icon is located at : /usr/share/icons/Papirus-Dark/[whatever-size]/panel/start-here.svg
