do you have the correct number of speakers being addressed?:
This is also for HDMI but might help you with a tip or two? (its oldish but still might help!):
Following this post here after continuing to research I have surround sound! Evidentially the module I needed was “k8x800” so by adding the following line to alsa-base.conf I got everything working!
options snd-ice1724 model=k8x800
Thanks for the help, have marked this as solved.
Glad to hear it, that link you posted doesn’t work though!.
