so amazing destro…
but how can i activate sound…
video only…pls…pls…pls…pls…help me.
Can you be more specific? Did you install UM 16.04.1?
Ubuntu mate 16.04.1 amd 64 bit version
Have you opened the sound settings dialog box and taken a look at the output tab?
I will take a look again… I think i heve tried all before… Any way thanks
for your support… Will keep you posted after i try that trick again.
After tried ubuntu mate many a times i installed linux mint sarah cinnamon.
It has no problem. All the necessary codecs can be downloaded at once after
installed it successfully.
I fell in love with ubuntu mate. But i cant use it because of the
particular audio problem. I hope Martin could help me. Please.
Again thanks for the support.
Pls help me.
You can install additional codecs. After you start the Welcome application go to Getting Started > Updates & Extras > Additional Codecs. Restart your computer and see if it works then.
I would like to know for sure the mic is being detected. Please run the following command in terminal and look for the mic in the output or just post the output here.
cat /proc/bus/input/devices
Finally installed codecs…
No use… Fed up
Can you take a screenshot of your sound settings dialog box and post it here?
Also run alsamixer
in a terminal and post a screenshot of that as well.
