Facts:
I am running a full installed 17.04 from an SSD, USD connected to my desktop ASUS AiO. Works fine, once solved initial newbie issues weeks and weeks ago. So, it boots direct from the SSD, although having to go through the Bios each time - but this is not really an issue (rebooting just once in a while and it takes just one more minute)
Question:
Can I just unplug the SSD and plug it (still USB) into my Surface Pro and run it ‘as is’ without having to tweak anything in advance ? What do you guys think ? The Surface already boots ‘USB first’. I’ve tested using 17.04 from my bootable flashdrive. Does work fine. Wifi, touch and keyboard & al. (except I didn’t use it for an extended period of time each time).
I’m asking this since I’ll be travelling for an extended period. Will need to connect and work on a daily basis. In my dream, the Surface and the SSD in a pack, easy plug in and boot, would do the job for me - since working with/from my usual desktop install, not from the flashdrive version. Don’t want to install dual boot on the Surface as of yet (not experienced enough and don’t want the risk of ‘screwing-it up’ just before leaving).
Although at some point I know I’ll wipe out Win10 from the Surface and get into UM fully. No way back.
I checked on AskUbuntu but didn’t find anything that would answer that question of mine, really. Lots of semi answers since trying to solve issues/problems after the fact and/or with some answers dating back to 2013… so nothing with a Surface Pro in mind…
All of your ‘watch this’, ‘look at that’, ‘beware of…’ of any kind will be welcome.
Thanks ! (in advance)
