I see my computer wake up sometimes when I’m not using it.
After some searching its the devices in /proc/acpi/wakeup that are allowed to do this.
By echoing the “4-character device name” to /proc/acpi/wakeup you can enable/disable these.
(eg: $ echo USB1 | sudo tee /proc/acpi/wakeup to enable/disable USB1)
I would like an extra panel under Power Management, called “Wake-Up Events”
or something, so i can check and uncheck these.
Currently i have solved this issue with a systemd script, but it could be so much easier just in a nice tab
Thanks a lot
For those interested, these are my devices, i enabled only the power button. So no mouse click, keyboard touch or wlan/lan packet can wake it up. (see systemd script below, change accordingly for your own benefit)
$ cat /proc/acpi/wakeup
Device S-state Status Sysfs node
PCI0 S4 *disabled no-bus:pci0000:00
PCIE S4 *disabled pci:0000:00:1e.0
USB1 S0 *disabled pci:0000:00:1d.0
USB2 S0 *disabled pci:0000:00:1d.1
USB3 S0 *disabled pci:0000:00:1d.2
USB4 S0 *disabled pci:0000:00:1a.0
USB5 S0 *disabled pci:0000:00:1a.1
USB6 S0 *disabled pci:0000:00:1a.2
EHC2 S0 *disabled pci:0000:00:1a.7
EHCI S0 *disabled pci:0000:00:1d.7
AZAL S3 *disabled pci:0000:00:1b.0
RP01 S4 *disabled pci:0000:00:1c.0
RP02 S4 *disabled pci:0000:00:1c.1
RP03 S4 *disabled pci:0000:00:1c.2
RP04 S3 *disabled pci:0000:00:1c.3
RP05 S3 *disabled
RP06 S5 *disabled
LID S3 *disabled platform:PNP0C0D:00
PBTN S4 *enabled platform:PNP0C0C:00
/etc/systemd/system/acpi-wake.service:
[Unit]
Description=ACPI Wake Service
[Service]
Type=oneshot
ExecStart=/bin/sh -c "for i in $(cat /proc/acpi/wakeup|grep enabled|awk '{print $1}'|xargs); do [ $i != PBTN ] && echo $i|tee /proc/acpi/wakeup;done"
[Install]
WantedBy=multi-user.target
To enable and start the service
$ systemctl start acpi-wake.service
$ systemctl enable acpi-wake.service
