Is there a way of adding more time options to the Power Management? at the moment the lowest is:
computer sleep is 10mins and screen sleep is 1min
I did try dconf editor 120sec but that only worked for the screen. This is for suspend by the way on ac
Yes I did wolfman, the display did work but not the computers sleep.
I will try it again and try rebooting this time. Unless there is another way?
Thanks for that wolfman, while that fixes the screen blanking after 5mins, my pc still does not suspend to ram after 2mins or what ever I set it too (using dconf).
Thanks again
Sorry about that @antechdesigns, I don’t use suspend or hibernate or any power saving settings as I don’t like screensaver and CO!.
Maybe someone else on the forum has an idea?.
