I am using for some time this ppa and the mentioned package
I observe that in both 22.04 and 22.10 there are two icons missing in Control Center...
Mate Tweak
Indicators
Hope maybe @lah7 or someone might fix this issue.
I love this Theme, and I don't intend to move from this theme in the feature, only if it remain unmaintained, and it brakes.
I use this icon for 'indicators' /usr/share/icons/hicolor/scalable/apps/ayatana-settings.svg
I use this icon for 'Mate Tweak': /usr/share/icons/menta/256x256/apps/background.png
I remember that I had to spend some time to find suitable icons.
I also love this theme and I will keep it on my systems as long as i can.
I do not have write access to the PPA but I am prepared to help out any way I can to keep this theme from dying.
I hear you! I don't daily drive Ubuntu MATE or the theme/icons myself, so I'll need to be notified whenever something breaks. Ideally by creating an issue on the Git repository. Even better, create a pull request.
This one was a bit weird, since its .desktop file in /usr/share/applications hardcodes the icon to /usr/share/icons/hicolor/scalable/apps/ayatana-settings.svg, but for whatever reason, the one in MATE Control Centre expects an icon named system-component-addon.
I added the icon, but it didn't work in my testing.
Since I kept the desktopfiles, that i changed, in $HOME/.local/share/applications
(which actually works) I never noticed that.
But for this cause, I just deleted them and made the changes in /usr/share/applications and indeed it doesn't follow the settings in ayatana-settings.desktop
It is, however, not hardcoded:
Tracing links back and forth, I discovered there is another .desktop file: /usr/share/mate/applications/ayatana-settings.desktop which indeed has the line Icon=system-component-addon
If the patch is made against /usr/share/mate/applications/ayatana-settings.desktop instead of /usr/share/applications/ayatana-settings.desktop I bet there is a high probability that it will work
Sorry that I can't send you a pull-request (I don't have a github account, and to be honest I don't even know how it works ) but I hope you can do something with this info.
EDIT: Changing that desktopfile will probably damage other themes so I guess that the Ambiant-MATE icon theme needs a copy of (or softlink to) ayatana-settings.svg named system-component-addon.svg or something like that
Good find! Thanks for the info. I'm a little rusty with MATE, but did vaguely suspect something somewhere was different for MATE Control Centre (which I never really used). If I recall, the icon in the System → Preferences icon is broken too.
I did add system-component-addon to the categories/scalable folder, but in hindsight it might need to be apps/scalable instead.
While symlinking is possible, it's bad practice for the theme to be making links outside our own theme. It seems every non-Yaru theme is broken.
Yes indeed, it also contains the line Icon=system-component-addon
But it is, as far as I can tell, not a seperate desktopfile, it is merely a link.
When I removed my local version of the desktop file, the icon in both control-center and system -> Preferences disappeared.
So it is either patching Yaru to be compatible with the rest or patching everything else to be compatible with Yaru or a case dependent workaround. This could be getting messy real fast. Not a pretty sight.
P.S. I don't know if you have Ubuntu-MATE running but if you don't I am fully prepared to test stuff for you if needed.
The only thing that I may have got wrong is that it may need to go in "32" instead of "scalable". It's been a while since I've dealt with icon themes. Pretty sure there may be a cache to deal with as well.
In /usr/share/icons/Ambiant-MATE/categories/, you could try moving it out of scalable and into 32 instead (as root). I can see that Yaru put this named icon inside categories, so my previous comment about maybe needing to be in apps is incorrect.
I only have Ubuntu MATE in a VM, but I'm focused on other things at the moment. I think a more proper fix is to change this MATE-specific ayatana-settings file so it uses the same icon as the /usr/share/applications version, so it's fixed for all themes. This command will tell which package installed this file:
