Any of you ever tried Y-PPA-Manager ?
IS it doing exactly that? i.e. automatically re-enable and update any PPAs that provide packages for the new version of Ubuntu ?
Enabling Y-PPA-Manager means using the following commands in a terminal:
sudo add-apt-repository ppa:webupd8team/y-ppa-manager
sudo apt-get update
sudo apt-get install y-ppa-manager
Just wanted to see if anybody had experience (i.e. actually used it) and if there is any simple advice to know about.
Thanks
W
