to print many pdf files without first opening them with the PDF wiewer, in a terminal type “lp” followed by a space, then select all the pdfs that you want to print and drag them to the terminal, enter.
Instead with
lpstat -p -d
You can see the printers installed, configured and available on the system, and also the default printer.
Lp is contained in the CUPS package
It also works with Jpeg.
