Print Screen does not take a screenshot
Since the last update pressing "Print Screen" brings up the following error message:
"There was an error running mate-screenshot:
Failed to execute child process “mate-screenshot” (No such file or directory)"
GNOME screenshot is only available via the Applications menu and it looks unnecessarily complicated.
I don't know whether the issue is with MATE's keyboard shortcuts or with the actual screenshot software.
Hi :slight_smile:
Do mate-screenshot is starting if you are running it from a command prompt ?
If not, you can try installing it with :
sudo apt install mate-screenshot
I had to use:
sudo apt install mate-utils
... but basically you were right.
Thank you, Sir!
I owe you a beer.
