Hi
I ran the tour service with the following command ==> apt-get install tor
but it does not work properly and the sites are still filtered, then uninstalled service
i cant go to this site without vpn and its need running at Installation time
found this link Why and how I can enable Tor Package Repository in Debian? | Tor Project | Support
I did what was written inside the site but in the end, when I execute the following command, it gives an error apt update
I added the star * character in the error text myself because it is not possible to put more than 2 links in the post
and this is the error
apt update
Ign:2 https://deb.torproject.org/torproject.org kali-rolling InRelease
Ign:3 https://deb.torproject.org/torproject.org InRelease
Ign:4 https://deb.torproject.org/torproject.org tor-experimental-0.4.6.x- InRelease
Get:1 http://ftp.halifax.rwth-aachen.de/kali kali-rolling InRelease [30.6 kB]
Err:5 https://deb.torproject.org/torproject.org kali-rolling Release
404 Not Found [IP: 95.216.163.36 443]
Err:6 https://deb.torproject.org/torproject.org Release
Err:7 https://deb.torproject.org/torproject.org tor-experimental-0.4.6.x- Release
Reading package lists... Done
E: The repository 'https://deb.torproject.org/torproject.org kali-rolling Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'https://deb.torproject.org/torproject.org Release' does not have a Release file.
E: The repository 'Index of /torproject.org tor-experimental-0.4.6.x- Release' does not have a Release file.
and this command error : apt install tor deb.torproject.org-keyring
E: Unable to locate package deb.torproject.org-keyring
E: Couldn't find any package by glob 'deb.torproject.org-keyring'
I hope you can help me and thank you
Thanks for your guidance and I almost started working with Kali Linux
